Yahoo GO 3 Error Blocked
1 replies · 1,796 views · Started 09 January 2008
I install over Version 2, on my Card, since I found this program very slow I try to uninstall, it did not uninstall, the Icon is there and does not work either.The Icon is there, but does not work and is not in my "APP Manager" Let me know what should I do?
Regards
Carlos
I had a very similar problem today as well.I had a ghost file of a game(Alpha Wing) that I had downloaded and deleted a while back.I happen to see the icon in my Applications folder even though I had already deleted it.Or so I thought.So I tried to open the game,but nothing happened.So I went over to the "Apps Manager" and saw that it was installed!Even though I had deleted the file.So I tried to remove it again.But I got a "Remove Failed".So I did a hard reset being that I had a backup.But forgot to pull my card.So after it got back to the today screen it started to install my apps.I ended it.But the damn icon was still there.So the way that I solved the problem was that I copied all my files that I wanted to keep onto my pc.Then I formatted the card.Problem solved.But I did have to hard reset my phone to get the icon to go away.Maybe someone else has a better idea than mine.So wait and see if someone comes up with a better idea.But this did work for me.Hope this helps.The stupid icon was aggravating me beyond reason.So I know how you feel.
