Outbox Msg. Won't Delete
6 replies · 2,742 views · Started 27 January 2003
This is a long problem of mine and now I give up...
Any of you guy know this problem? Or maybe encountered it?
Well Basically, the problem is I've a message that can be located at the Outbox message. it won't send and it won't even be deleted. You can just simply check the message detail.
it really sucks man....
Any of you knows how to solve the problem????
Your in luck!... yea, got that bug before... all you have to do is have an upgrade... well, thats what the tech guys of nokia did to my fone to solve it... but just make syur to back up first 😊 hope that helps...
Already Back-up my documents..
Question:
If you backup your documents, will the Outbox thing will be backup too? Just wanted to know coz it really sucks if It does coz' when you restore, for sure the Outbox thing will sure be there again... ^_^x
Hey pidz... (hehe.. my friend call me pids too. ^_^x)
Are you also from PHilippines? I'am ^_^x
Were did you upgraded your Cellphone?
What kind of upgrade? The firmware thing?
How much did it cost you?
Just wanted to have a little info. Thanx!!!
Im not sure... 😃 i think it wont bug you anymore.. i think. Yea, Philippines too, cebu. u? is ur name peter too? hahaha 😃 . i didnt pay anything coz it was still in its waranty period, i bought it sa globe kasi. i sent it to semicon for repairs
