Map making For N95 / symbian
4 replies · 2,628 views · Started 09 January 2008
Hi, I was wondering if anyone knows a about a good software to create my own gps maps for my N95?
For Garmin units (or in the case of the N95, Garmin Mobile XT) I use MapEdit and Global Mapper. These make it fairly easy to map out towns, add points of interest, street names, numbers, traffic flow and so on.
There are lots of commercial apps that do the same too.
Can you use this to change bought maps? Theres a few mistakes Id like to correct on mine.
Einar wrote:Hi, I was wondering if anyone knows a about a good software to create my own gps maps for my N95?
Its impossible but you can buy one from youpark.com
zippiracer wrote:Its impossible but you can buy one from youpark.com
youpark.com - yes, provide a helpful link to the front page of a busy site with absolutely no relation to the subject matter.
Smart 2 Go maps are not publicly documented. While it is very likely possible to modify those maps, it's impractical and not worth the effort to reverse engineer given the prevalence and openness of other mapping systems.
If you want to have full control over your maps, then at this point in time Garmin is your best bet on the N95.
http://www.geopainting.com/en/ GPSMapEdit. Works with several sources of map data.
http://www.globalmapper.com/ Global Mapper, works with a long list of source data.
ArcView http://www.esri.com/software/arcview/ - another nice commercial application.
