Web Run Time (WRT)?
3 replies · 3,492 views · Started 10 January 2008
Web Run time is just a software engine which allows widgets created using html, css etc to be run on the device. You therefore won't see a WRT application but you can now use WRT widgets, if you can find some to download
Ok, I see. Anyone knows where I might find some of these widgets to download?
And what about the "video editor"?
Hi Fender2
The only place i was able to find any was at Mosh here is a link
http://mosh.nokia.com/
either search wrt widgets or just widgets but don't expect to much the only ones i found of interest was a Battery level indicator, a Network signal indicator and a Weather widget.
Marc
