when i copy text the two buttons that are used on the 95 8gb are far too close together its really difficult.
Paste is ok.
Anyone else found this?
liam
Paste is ok.
liam
No 😊
The only problem I've had with using the edit/pencil key is making multiple selections when the phone is in landscape mode. I either have to switch to portrait mode or hold the phone arkwardly to make my selections.
you cant use the same finger to copy text. The pencil button and the copy are right above each other!!
It might be the result of the main buttons on your N95 8Gb being smaller and closer together. I have an N95-1 and it's pretty easy to use on mine in portrait mode.
