More advanced calendar on N95
5 replies · 2,102 views · Started 11 January 2008
I have a re-occuring appointment in my outlook that shows the date when it was started from, however when I look at this on my N95 it says this year but in outlook it says 2004 which is when it started from.
Isn't this information sync'd to the N95?
Are there any other calendars that will do this?
There is HandyCalendar and few other commercial apps available but I'm not sure if they will do what you're asking here specifically. You can check out what calendar apps they have over at handango.com and download trial versions and see if they work for you or not.
you could look at Papyrus from SBSH. A very good calendar for S60.
Ok will give papyrus a try..
Do you know if this will also display the age of the person on a birthday reminder?
Ok just tried papyrus and looks ok and lets you set a birthday and will show age, however it doesnt do it based on the information that has been syncd from outlook. It does show when the date was effective from but doesnt display the age unless you select "birthday" under the setting of the entry and then it gets rid of the effective date so it shows they are 0 years old...
Handy calendar not any good for this...
Any other ideas?
