I have an N95 and sync with my work PC and my home PC. I sync mainly my calendar and contacts and don't get great results when syncing with both PC's.
Basically if I have a calendar entry in for say 1/1/2008 on home pc, work pc and n95 and then on my work PC I change this to the 2/1/2008, this syncs ok to the N95 and changes the entry but when I sync my N95 with my home PC I end up with an entry for the 1/1/2008 and 2/1/2008.
I have the settings on both PC's to update in both directions.
I also get a similar occurance when I delete a contact on one PC it get put back by the 2nd PC...
Urghh...
Is there any better syncing software out that specifically overcomes these issues.
I am using the latest verion of PC Suite from the Nokia web site..
