how can you tell which radio is in your phone? does the product code tell you which radio? I have an N95 8gb with an original US product code. Does this mean I have the model that is US 3g certified? PLEASE REPLY!!!!😡
How Can I Tell
The model number is how you tell. Product codes are more for firmware customizations, hopefully my version of the product code means the same thing as yours. (the longish number 5xxxxxx)
*#0000# will give you the model number (usually RM - followed by 3 numbers)
