is my handset faulty on 3uk
1 replies · 1,983 views · Started 12 January 2008
had mine for a couple of days now and i have found that the menus are very slow loading compared to the n95 also if you go into messaging and scroll across the sent/inbox/outbox there seems to be a delay in accessing the menus and the content
also its slow coming in and out of programs to.
when you check the mass storage memory it takes ages accessing the info does anyone else have this issue seems to have issues loading from mass memory could i have a faulty unit or is it the same for every one and if you have upgraded can you cancel the upgrade with 3uk
What firmware are you on? *#0000# to find out.
My guess is that you should de-brand, and get the latest firmware. Loads of information around, check the stickies at the top of this forum.
