Birthday in contacts.. can i make it a reminder??
5 replies · 3,360 views · Started 12 January 2008
My problem is that when i enter a contacts bithday in the n95... it simply does nothing...
when the birthday comes. the phones does not remind it, and in the calendar does not appear as if that date is the borthday date...
can i make this happen like in the other nokia non symbian phones???:icon4::icon4::icon4:
PLEASE HELP!!
Sync with outlook.
Outlook should create birthday alarms and calendar events for birthdays for you when you resync.
you have to add the date to your calendar as a calendar entry. eg. "Fred's Birthday" on Feb 20th you will just create an entry in the calendar as that. Set the reminder to be ON to be days or weeks in advance (as reminder) and reoccuring annually.
ive also solved it with papyrus... it imports the birthdays from contacts and paste them to de calendar...
