How to delete a Theme???
5 replies · 7,908 views · Started 14 January 2008
Guys Please help me....!!! How to delete an installed theme??I tried to delete it from Application Manager, but that particular theme is not displayed there?Is there any way to delete it by connecting to a PC?:con?
Throw the APP Maneger .... all the theme's that you put or Install will go to the APP Maneger .... go there and click on"Option's" and Click"remove" ....
I hope This will work Try It...
If it doesn't Work then Install ActiveFile ... That will enter you to the SYStem File's and Delete it .... ADVICE::: Don't guess wich file's are contain's to the theme ... it's hard to know....... DON't PLay With The SYStem..
Thankx...
Hi Kelwa, I tried to delete it thru App manager, that particular theme is not displayed there...And what is Activefile? From where shud I get it?
Thanks for your reply....
Active file is A App for nokia phone's that give you a way to the SYStem file's ... & it's the best of all SYStem Explorer , you can find the whole RAM that you will found even the ringtone of your phone .. the orignall and becareful because any deleting in any file could harm the phone that you can't Re-back .... Even if you Format the phone ... because this a SYStem File's .... Search About "ActiveFile for S60 3rd Edition" ....
Thankx...
