N95-3 (US Version) Car Charger
3 replies · 2,302 views · Started 14 January 2008
Is the DC-4 Car charger the one to use on the N95-3 model? I do not want to purchase the incorrect charger for this phone...and tigersdirect (where I bought it from) does not show any chargers at all.
Ebay is crawling with them but they list them as N95 which might mean 1st generation.
Is there really any difference? It would be nice to use the GPS in the car w/o fear of the phone dieing on long trips TT
I think all the N95 types are using the same chargers.
But I'll buy the original one, because the plugs of some of the nonbranded ones don't fit too well in the phone's socket.
rottie wrote:I think all the N95 types are using the same chargers.
I want a branded one as well but Nokia does not list it on their site...for whatever reason.
I was going to buy the charger and the keyboard at once but I don't see it so..dunno.
That and the N95-3 uses a different battery type from the 1st gen N95
all nokia's use the same charger. for recent handsets anyway. i just went to ATT store and bought one there. though 30USD is totally a rip off my face off!
