Hello all,
Can anyone tell me what size torx screwdriver do i need to use to unscrew the slider tracks on each side of the N95 8GB??
Hello all,
a T0.5
Im hoping i dont need to but i have a feeling i will need a new lense at some point on my 8g despite me being as careful as I can.
I presume the same size will work for this?
This is the part I mean
cant answer that one mate.. sorry.
Liam548 wrote:Im hoping i dont need to but i have a feeling i will need a new lense at some point on my 8g despite me being as careful as I can.I presume the same size will work for this?
Scratches on the lens do make quite a difference: http://www.n95users.com/forum/general-95/8289-replacing-nokia-n95-camera-lens-amazing-huh.html
I'll find out where he got the lens from.
And it appears you need both T5 and T6 for the N95: http://www.n95users.com/forum/general-95/8314-torx-driver-size-needed-open-nokia-n95.html
yes, perhaps I should have said T5 as its the more common name...
anyway, it IS a good idea to just pick up a range... they always come in handy.
I tried a T5, it seems to be too big for the screws on the slider tracks. Does the n95 8gb uses different screws to the n95?
Urm, good question... you do have to be a bit gental with it... have you tried a 1/2 size or a torx+?
It seems that Nokia use a T5.5 in some cases. What's that all about?
HI
Looking for a definitive answer on this if poss please. Has anyone opened up the face cover and if so which torx screwdriver fit best? Did you manage to use the same screws?
Crispy
i just took apart my n95 8GB last night, and the tutorial says T5. but that started stripping my screws, so i used T6 and the fit was perfect. i found a complete torx set T1 -T10 for about 6 USD at the hardware store. so just grab a set and you have them all.
