I tried searching this forum but found nothing. Is there any way to move around the icons on the main screen (Ph. Book, Messaging, Web, etc) ?
Move icons on main screen
(Left soft key) Options > Move
what? no, to move the active standby icons, go to settings, personalization, active standby, then shortcuts. you can set each one to whatever you want. also you can change the left and right softkey to whatever you want.
RogerPodacter wrote:what? no, to move the active standby icons, go to settings, personalization, active standby, then shortcuts. you can set each one to whatever you want. also you can change the left and right softkey to whatever you want.
That is exactly what I was asking about :icon14:
Many thanks !
Ah, I thought it seemed too easy lol
aye, was the 'main screen' terminology that threw me too..
kontraband wrote:aye, was the 'main screen' terminology that threw me too..
Yeah, my bad, should have used different terminology.
razmataz wrote:Yeah, my bad, should have used different terminology.
Nokia refer to this screen as the "Standby Screen". 😊
maybe standby screen or idle screen, but I understand main screen now too as opposed to menu screen... so many choices! 😉
At the time of the thread it slipped my mind and did not know how to refer to it. At some point I wanted to call it "desktop" 😊
haha yeah, Ive heard that one many times 😉
