2 questions would appreciate assistance!
16 replies · 3,010 views · Started 16 January 2008
Hi there. Getting an N95 8GB sent to me hopefully by the end of the week. Just a couple of questions. Firstly I will be debranding the phone and need to know if it's possible to keep spiderman. I have searched on here but couldn't find an answer.
Secondly I wanted to know what the best free to use GPS software is (including maps.) Also what the best paid one is. Thanks.
There isnt many 'free' Satnavs. I think 'Amaze' is, but Im not sure. Either way,it will charge you data as it downloads maps on the go.
http://www.amazegps.com/welcome.php
Nokia maps isnt free for navigation, you have to pay for turn and voice guidance.
Currently, the best paid for one is Garmin, although thats open to speculation.
Not sure about the spider issue, sorry.
the spiderman issue has been talked about many times on here... have another look.
kontraband wrote:the spiderman issue has been talked about many times on here... have another look.
I looked but couldn't see anyone giving a proper answer. The best solution I found was download it in avi format!
bartmanekul wrote:There isnt many 'free' Satnavs. I think 'Amaze' is, but Im not sure. Either way,it will charge you data as it downloads maps on the go.
'm on T-mobile and have web and walk. Will I not be able to use GPS without paying?
Depends which one your on and how much you use GPS (and other data). Web and walk, depending on the package has limits. If you go over them you will be charged.
re spidey check out Liams thread called 'quick question about upgrading firmware- N95 8GB?'... or .... even... PM Liam... Im sure he'll be happy to advise.
Its good that you have asked the question mind, before you debrand it. 😉
bartmanekul wrote:Depends which one your on and how much you use GPS (and other data). Web and walk, depending on the package has limits. If you go over them you will be charged.
Well I'm working on the assumpton I won't go over.
Just read the small print and it appears you have 1GB, which is pretty good. Best to check your package though, as Im not sure all web n walk is the same.
You wont pay for anything if you use amaze. There might be other free ones out there, but in my expirence they are not as good as traditional satnavs.
Cheers guys. Just read that topic and am still none the wiser about spiderman. Should I be performing a backup? Lots of people were saying it wasn't workin for them.
well, I dont think anyone can say for definate ... the backup process is shakey at the best of times...
PM liam or any of the others in that thread and see if you can piece a proper route out. Good luck.
OK I'll continue my hunt! ANy particular applications you would reccommend?
haha yeah, theres a few... have a ..... search! 😉
I think that question has been asked a few time this week so they should be on the first few pages... I think I am going to take up that suggestion someone made about having a sticky....
search under my username Liam548 and find the thread that is mentioned.
I have upgraded my firmware twice now and am on the most uptodate version and still have the spiderman with no problems.
I used the betalabs Nseries pc suite and backed up and restored everything and it works fine.
Try this.
Liam
and hypo... Ive started a sticky thread ... check it. 😃
