Adobe reader recent docs help
6 replies · 2,278 views · Started 16 January 2008
How do i delete a recent document. I have not saved it but it is listed in the recent docs when i open adobe reader.
Where are they stored? I have Y browser should I need it although I really dont think I should.
Liam
Have you tried just selecting it to open? Maybe when it can't open, because it's not there, it it will remove it from the list.
thing is it does open it. Ive no idea how I dont recall saving it and cant find where it is saved to!
it must be saved somewhere, wheres the likely folders to check people?
It could be anywhere. The program doesn't have a default folder location for saving files. Any saved files are placed in folders of the user's choice. Your best bet is to get Y-Browser to search for the program and determine the folder that way.
yeah, just save a file, then use the search option to search for that name with the browser and see where its stored maybe??
