msn live not working with 3net work,help
5 replies · 3,302 views · Started 16 January 2008
Hi ive updated the firmware on my nokia n95 8gb,i had to change the product code to do this and since then ive lost some of the 3 network things like mobile ebay etc....i also cant get msn live working,i downloaded it and it just wont login,also with my 3 contract i am ment to get unlimted use of msn live,does that mean free usage of msn live that i downloaded of only the one originaly installed on my phone?
thanks
brett
strobez1977 wrote:Hi ive updated the firmware on my nokia n95 8gb,i had to change the product code to do this and since then ive lost some of the 3 network things like mobile ebay etc....i also cant get msn live working,i downloaded it and it just wont login,also with my 3 contract i am ment to get unlimted use of msn live,does that mean free usage of msn live that i downloaded of only the one originaly installed on my phone?
thanks
brett
your unlimited MSN use on 3 means you need to be using the 3 branded MSN. Have a look on the forum as theres a few posts about this issue and debranding 3's N95. Dont have 3 myself, so not 100% sure of the remedy, but as I say, have a look here cause I know its talked about.
yes,i can get tp the msn on my 3 web via my mobile phone but when i try to install the 3 version it gives me a certificate error.is there a way to fix this?
ahhh, do you have the latest version from 3 then?
In the app manager settings, set Software installation to All, Online certif. check to Off
and
try setting your phone back a year in date or so...
I have the latest nokia firmware, i had to change to the code.i just checked the settings and software installation is set to all and check to off.i havent tried changing the date though
nah, I meant the latest download of MSN not of the firmware. Try a couple of dates... see if they work... it make just be an old cert date for that app.
Try the date bit... Ive just had a search on the forum and see ScottE90 had the same problem but noone solved it. He might have, try PM him?
