Medical programs on N95 8GB
4 replies · 3,185 views · Started 17 January 2008
Can someone tell me whether the N95 8gb can be loaded with medical programs, such as Harrison's Onhand or MIMs PDA (Australia drug info program), or 5 Minute Consult?
Or should I be looking for a PDA phone to buy?
Thanks,
Chris.
Thanks,
I saw Harrisons there as well. So would these (and other programs) be easy to use in a work environment even without a touch screen or stylus?
Chris.
Your probably the only person that can answer that, as people have vastly different opinions on what works best. Personally I dont like touch screens.
Best thing is for you to give it a go, see how it works out.
if your looking for a larger screen then Id say you gotta be looking at WM devices. unless you want to output to something from the N series, but I doubt that you do.
