Hello forum,
maybe some symbian expert can halp me with the following prob:
I sync my N95 8GB with the outlook-calendar.
All-day meetings are synchronised as "notes" in the N95, so I can neither move this item nor change the time of the reminder-signal.
Has someone any idea?
(Sorry for my probably at least uncommon english, its not my mother-tongue)
Thanks for your help...
If your problem is that you cannot change the alarm time on all-day appointments you could switch to using Handy Calendar instead of the built-in calendar program.
Buy it at www.epocware.com or in the software store here at AAS.
Thank you, this may be the easiest solution. I�ll try the demo and see..
do I understand this right?
If you have an appointment set in your Outlook calendar and then sync the N95, it becomes a Note on the N95 and not a calendar appointment?
kontraband wrote:do I understand this right?If you have an appointment set in your Outlook calendar and then sync the N95, it becomes a Note on the N95 and not a calendar appointment?
Hi Kontraband, an ALL-DAY meeting in Outlook becomes a MEMO on the phone. I have no idea why, it is annoying!
Normal appointments (between two times, even if spread over multiple days) in Outlook become Meetings on the phone, exactly as you would expect.
To Akrobat, I'm afraid all I can suggest is to set start & end times for all appointments, like 00:01 to 23:59.
ahhh memo... yes... it was the fact it might have being turned into a note that was confusing the hell outta me! Tis strange.
