I have successfully set up SIP and registered the 5500 with a VoIP provider, but I cannot make or receive calls. The SIP connection shows that it is registered. There is no "Internet Tel." connection on the 5500 like there is on the E61 (which works fine). I downloaded and installed the Nokia SIP configuration tool. I tried putting an entry under Internet Tel in the contacts, but that does not work either (format: #@domain). Any ideas?
Updated: 20 Jan - Fring works okay as a client but it does not support DTMF over a call (this has yet to be developed).
