Hi everyone. I installed the latest firmware for my N95 this week and the whole process went without any problems. However now my N95 battery is lucky if it lasts 24 hours, without much use either. Can someone please help me and advise what to do?
Many thanks
Lilly
Check if you have some background open applications by default, like Wi-Fi, or another battery drain application. That should not occur!
Changing the firmware shouldnt make any physical difference to the phone, so most likely some settings have changed like nj7 says. check the network roaming/detection settings too.
If you cant find anything wrong in these it may be worth re-installing the firmware
