Forgot Nokia 6630 Lock Code
0 replies · 23,469 views · Started 20 January 2008
FIRSTLY, I tried making an account but it didn't like any of my usernames, no idea why
But now the problem...
When I turn on my 6630 to get the old numbers off it, it says "lock code". I've tried my old pin code and the default lock code (12345) but with no luck.
I found this
http://www.allaboutsymbian.com/support/item/Ive_forgotten_my_lock_code_How_can_I_get_back_into_my_smartphone.php
and it says
One free alternative is to use the applet currently at http://nfader.z-host.ru/, which generates a master code from your IMEI number and you can use this to gain access and reset the lock code yourself.
i've found sites that can generate a master code from IMEI but i dont know what to do with it.
really appreciate if anyone has any ideas
