hi,
i bought e62 sometime bak..facing a prob first thing is dat its battery isnt doing v at most a day wid out much use and dere is an image jpg wid v long name on the c:\ wid a couple of other files 1 somethin like irdaOS2BA.esk and a preinstalledapps cache.dat
i cant delete dem error says mobile phone is rejecting operation. are dese some kind of virus or somthing and something to do wid da low battery.
cant format the phone ive also tried formatting with *#7370# but even dis doesnt even remove the call logs wat to talk of others..just restores factory settings
tried updating also but found no update for ma phone may b coz may b nokia removed e62 from the nsu..so nothing happening
plz suggest..
thnx in advance
