Hello.. When i use opera.. It sometimes randomly freezes.. The phone locks then restarts after a few minutes.. Whats the latest version.. I have 4.0.9800 Is this old?
Opera mini version
If you've downloaded it from opera.com then you have the latest version.
I've never encountered any freezing during it's use. Make sure you don't have any applications auto loading on start up.
Are you on the latest firmware?
Opera should release symbian version of Opera Mini, because java version works really clumsy (N95 8GB).
waxup wrote:If you've downloaded it from opera.com then you have the latest version.I've never encountered any freezing during it's use. Make sure you don't have any applications auto loading on start up.
Yeah version 20... I have call man running but it happens even when it'r not running.. Do you know the latest version?
The latest is 4.0.10031
uninstall yours and try this one
http://mini.opera.com/global/opera-mini-4.0.10031-advanced-int.jar
hope that helps.
waxup wrote:The latest is 4.0.10031uninstall yours and try this one
hope that helps.
Is this the most latest version?
oxfordmark wrote:Is this the most latest version?
Yes, it's right from the Opera.com website.
Does everyone else have to accept that they wanna "send and receive data" and "Choose access point" every single time you start Opera Mini because there is no DEFAULT setting, or was there something wrong with my installation?
Why would you use an internet browser if you wouldn't wanna "send or receive data"?? Doh!! 😉
rottie wrote:Does everyone else have to accept that they wanna "send and receive data" and "Choose access point" every single time you start Opera Mini because there is no DEFAULT setting, or was there something wrong with my installation?
I think you can't skip this question in java applications. It's some kind of security feature in S60 3rd platform.
