java games
5 replies · 1,731 views · Started 23 January 2008
i've downloaded some jave games and they have jar and jad files. what do i do with the jad files
Personally I never use them. They seem to come with most (if not all) java games but you never really need them.
The jad files are for older phones i believe - i think they are a "Java Description File" which tells the older phones what to do with the Jar files
Although i might be wrong with my description (as i cannot cite a link to where i know this from), i would be 99% certain that you will have no need for these files with your N95 😉
I have a bunch of JAR files, the JADs for which I have long since binned. They still install and work perfectly.
wookie is right, they're just a different bundle. just like zip and rar.
infact a jar is a zip and can be extracted with winrar.
Nokias don't need the jad, Samsumgs and S-Es do
As has been mentioned a jad is just a text file that tells the phones that need it what class to run to start the game
