On my 9300 I thought that when you click the second button, Send button, when not dialing that you could switch from dialed, to missed to received on the front. I can only find it on the inside. Is there a way to do it from the send button on the front please????
Thanks,
Bobby
I actually had a another question related to my first one----I though you could turn the volume up or down on the top cover too but the up and down or side ways arrows when talking but that doesn't seem to work either.
Thanks,
Bobby
The SEND button will let you select from up to 20 of the last dialed numbers.
For MISSED calls, you must be in the view missed call list which is prompted.
For changing the volume, the SCROLL key increase/decreases the volume while in a call.
Thanks for your response. Yes I got the volume ok and it looks like you have to open the cover to get to the missed calls. That is fine too but my E62 has it where you can go from called, to calls and missed calls. I thouht that my 9300 had the same thing.
Thanks,
Bobby
When I miss a call on my 9300, the outside phone shows:
"1 missed call"
When I unlock the outside phone, there is a soft button "List" where you can open the Missed call list. You then have "Options" "View" and "Exit" shown for the softkeys.
In addition, if you use the outside phone menu, the second menu item is "Call Log" and the first option in its submenu is "Missed calls".
All from the outside phone menu.
Thank you very much. I knew there was something some where that you could do that.
Thanks,
Bobby
