As the title says, I had on my phone ebuddy installed. I noticed there was a new version so I installed it, expecting it to overwrite the previous version but it didn't - leaving me with 2 icons on the menu for the same program. So I removed ebuddy but one of the icons remained ut doesn't do anything when I select it.
without completely rebuilding my phone (which takes hours) - is there any known way to remove it?
Mike
have you gone to the icon and pressed 'c'?
gotta check the obvious... are both installs of ebuddy removed? From app manager or from the program screen?
I removed one from the program screen (pressing the C button) and it has gone and no occurances exist in app manager BUT I still have an icon in my menu which I do not know how to remove (without a scratch install of the entire phone which is a real PITA).
Mike
Is ebuddy java prog ?
I had the same issue with amaze gps nav. software. it seems only phone format
can help in this case 😞
I know it is annoying, but if it doesn't bother you too much, just move the icon to a folder you'll never look at (Tools -> Utilities for me) and forget about it until the next time you need to flash your phone.
It's what I'm doing atm with a WidSets icon which doesn't want to go away. A bit of a waste to spend several hours setting everything up from scratch just for that.
Thanks for your responses. I will take your advice and just move it to an unused folder until the next N95 update (now thats a new topic on its own!)
Mike
kontraband wrote:have you gone to the icon and pressed 'c'?
I know this is an old thread but it showed up in a forum search and I just wanted to say a quick 'thanks' for reminding me that you can do this. Flickr's 'zonetag', now irrelevant, had disappeared from Application Manager, but I was able to remove it using this method.
