Guys, im sorry to post this as id imagine im missing something obvious.
ive tried for the past 2 days to get my thick head around registering, these2 amazing looking apps.
today i hit a final straw, i thought id got my head around it but after i did the final stage in the instructions.
10) Double click on auto_signsis.bat and a new file will appear [rotateme_signed.sis]
( I got my Devcert from symbiansigned no problem ) but nothing , no file , ive tried 3 times now, and tbh its annoying me alittle.
would someone be kind enough to help me out by reging for me?
You need to edit the auto_signsis.bat file with the names of your own files. The file's content by default is:
signsis xyz.sis xyz_signed.sis xyz.cer xyz.key 12345
you need to change xyz.sis to the name of your unsigned sis file, xyz_signed.sis to the name you want the signed output file to take, xyz.cer to the name of your .cer file, similarly for xyz.key, and 12345 to the password you used when you created the .key file.
As it's a batch file which will execute by default when you open it, you need to right click on the file and select 'Edit' in the pop up menu which appears, to open it in Notepad. Make the necessary changes, save the file, make sure all other dependent files are in the same folder, then run it and the signed file should be created.
Good luck!
Your a star thankyou so much 😊
I had not realised that the rotateme was the new version and not the version the read me had ( i was missing _beta5 )
also it appears in my anger earlier i deleted the Nokmote sis, could someone link me to it please.
again sorry for my noobness 😊
not to worry i had saved a copy on my external harddrive.
all sorted now.
Thanks again Randomfan.
Just out of interest I have both of these signed on my 8gb N95. Do they work together, or do they not. I cannot seem to get Nokmote to work.
for me yes they are working fine, ( alittle twitchy i admit ) have you installed it on the phone memory ?
i have a 4gb card, but have used the phone memory for both.
Yes I have both installed on the phone memory, I shall do some more tests.
