Problem with Nemesis Service Suite Program
7 replies · 26,622 views · Started 24 January 2008
I made use of the NSU to rewrite the product code of my N82 from (NIger)054984 to Euro-1 (0549174) . It wrote it all okay - now when i want to update; neither 'it' nor the NSS detects it. It just says "It can retrieve information from the phone".
I've reinstalled both NSU and NSS , and have also hardformatted my phone and retried -- the problem still persists.
Anyone with solution ideas?
nss does work, ive changed my product code to euro 1 and yesterday installed the new software update.
warning though my old version of nss did not detect the phone, you need to go to the b-phreaks site, full address not known and freely download the beta version its is called v1.0.38.12
it then works
cheers
wayne
there seems to b a problem with Nemesis service suite v1.0.38.12 when the latest Nokia software updater and Nokia Pc suite is installed whats the solution for this?
I found the same; NSS doesn't work with the latest nokia USB cable drivers. So you have to uninstall the drivers (they should be listed in add/remove programs in control panel) and then re-install the updater from your original driver CD. Worked for me!
hi, am using nokia n73... 73 has a prob tht some times it shows a msg tht memory is low, del some data.. so, i used to flash my cell ph using nss, but now i don understand y nss gives error while flashing the cell ph... When i click on the Flash or multi flash button it says, usb not implemented.... wat shud i do... kindly help.... !! 😊
