N95 8GB problem Realone player!!!!!
1 replies · 4,322 views · Started 25 January 2008
Hi my n95 8gb has a problem and the problem is the realone player when ever i try to play any media on the player i get an error message saying no activation key any ideas.
Have you tried to upgrade it to a full feature or are you still using the default installed player?
I've searched google but no such luck on this instance.
If you've not upgraded the real player to full then my suggestion is to reflash your firmware using NSU.
