Converting dvd to work on N81 ???
5 replies · 4,699 views · Started 25 January 2008
Hi, just upgraded to the N81 from N80, does anyone have any recomendations for a good dvd ripper to convert dvds to the N81??
I have loads of mp4's for my ipod but when i play them on the N81 they sometimes freeze and they seem to skip a couple of frames every few seconds!!
I've tried the Nokia media studio by Makayama using settings for N95,N73 and others (because the N81 isn't listed) but i have the same effect.
Nokia's own video manager will not install with the Nokia Nseries Pc Suite, i assume it only works with the non N series suite??
ANY INPUT ON THIS SUBJECT WOULD BE APPRICIATED - THANKYOU.
If you have access to a Mac, Handbrake is very good... As mentioned, Super is a used by a lot of people. You should be able to find guides to tweaking settings if you have a quick google...
GarysN80 wrote:Hi, just upgraded to the N81 from N80, does anyone have any recomendations for a good dvd ripper to convert dvds to the N81??
divx player, google it, convert to divx or avi..
easy
Hi i use Super for converting and ripping, its awesum quality on the nokia n81 8gb and with no freezing ect...try it you wont regret it..
