resize images
2 replies · 3,607 views · Started 25 January 2008
got an E70, i like to take photo's at the max resolution and quality for when i upload them to the pooter,
but occasionaly i like to send em via mms, but they wont go as they are too big at around 250 to 300k in size.
i have the re-size for mms set to large, but it dosent reduce them enough, they get rejected as being too large, set to small they go, but are useless when recieved even for viewing on a phones screen.
i can't seem to find a simple way to resize the image to be under 100k's easily.
anyone know different? just a simple select the image i want to send via mms, select the file size i want it to be reduced to, job done.
i'm sure i could do something similar to that on my last phone, the model before the E70, but then again i didnt have to use it, as the 1.3 meg camera took photo's with much smaller file sizes.
gazznsam wrote:got an E70, i like to take photo's at the max resolution and quality for when i upload them to the pooter,
Hmm.... on the E61i here, when you choose 'Send'>'Multimedia' the image automatically gets drastically resized (for phone screens), from 177k down to 5k in one example. Is this not automatic on the E70?
