Orite lads,
This is my first post so hello all.
Erm, well i have an N95 Plum (on Orange 😞) is their a way to remove it, ive searched but it only tells me how to on an N71 not an N95.
Thanks in advance.
Oh and when i change the Theme i still have the sucky Orange wallpaper i can use images btu not the actualy theme wallpaper? any ideas?
Hi and welcome
I suggest do a search on here for changing product code and debranding .It has been covered extensively so you should be able to find all the info you need then say bye bye to all the orange rubbish
joerobbo, your looking at de-brading to remove the orange stuff.... check the stickies on the front of this forum. They will tell you what you need to know...
themes, go check out pizero.net
