hi all, my 6682 has a problem occasionally hanging after i try to send a created text message. it will appear to send it but rather than proceeding with the standard system message telling me it has sent it will look like it is about to send then just blink back to the created text. at that point my only option is to delete it and recreate it or save to drafts. saving it to drafts does me no good whatsoever. i cannot delete any of my draft messages i am scared to know how many it has saved in the drafts folder,easily a few hundred.again i will highlight the draft , scroll to delete it will act like its deleting and then do nothing.
does anyone have any experiences such as this? also has anyone used y-browser with a 6682 i downloaded the files but i am not sure that sisx files are compatible, i believe those files are for OS9 only, 6682 being bb5 platform may not have the compatibility. i am not completely sure though. help!
6682 behavior with draft messages and memory
First, the last question...sisx files are only for S60v3 phones, not the case of yours.
First problem... which memory do you use? Phone or MMC memory for messages? Try use only Phone memory, because general behavior is more reliable, usually.
