e90 and ms activesync
2 replies · 5,485 views · Started 28 January 2008
Ok, next problem. I installed MS Exchange, as we have an OWA server. The e90 says it's installed, but I can't for the life of me, find it to start it. Not in the Installed Folder. The only file in the Microsoft Echnage folder ( not the MFE folder as the manual says) is an adminlog.txt file.
Anyone know how to start the program?
Hello,
I'm not shure but maybe you can find it in the sync app on the e90. Maybe it ads an extra function to the sync app?
Cherrs,
aschuman wrote:Ok, next problem. I installed MS Exchange, as we have an OWA server. The e90 says it's installed, but I can't for the life of me, find it to start it. Not in the Installed Folder. The only file in the Microsoft Echnage folder ( not the MFE folder as the manual says) is an adminlog.txt file.
What are you talking about MS exchange? There's a "Mail for Exchange" program under "Office" in "Download!" app. You just install it from there, run "Mail for Exchange" from the MfE (default folder) and it will ask you to enter the settings for a new profile. Then your email should by default start coming in on your Active Standby screen, or if you have that option turned off, then just go to Messages and go to "Mail for Exchange" to access your inbox.
