hi why dose my mobile say it version 15.0.015
and then when i go on the nokia website and type my mobile product code in it said the latest is 11.0.026
why is this and if this is wrong am i missing anything
(im using nokia n95 8gb)
n95 8gb product code problem
mikester585 wrote:hi why dose my mobile say it version 15.0.015
When did you get your phone. If it says v15 when you type *#0000# then you have the latest update. I wouldn't worry about what the Nokia site says.
You changed your product code using nss -
"the truth i was looking for gps maps to buy and i thought you could download them so there is this software called "nss" which basically reads everything about your phone and i too have the n95 8gb and it said change this product code to your region so i thought cuz i from england , united kingdom it must be euro1 and then it said just update your phone to latest firemwire and that was where 2 problems started "
Thats a copy and paste from one of your posts in another thread.
On reading the rest of your posts a few things become clear-
1 - Your phone is NOT unlocked to work on any network - try another network sim -I bet it dosent work.
2- You changed the product code to euro 1 and now have the latest software . Thats why when you look for an update your network code says V12 but you have v15 because you used the euro 1 code.
One last thing if you don't fully understand what you are doing with NSS software you will kill your phone and when you try to return it no one will fix it under warranty.
