Some people may be forgiven for thinking that a platform has not arrived until it is skinnable. If that is the case, then the Series 60 platform has truly arrived with the advent of WildSkinz by Wild Palm. This application will allow you to customise the look and feel of your 7650/3650 beyond the usual backdrop and/or today screen. Now the menus and dialogues can be transformed to siuit your taste.
Features include;
[list]
Easily transform the look of your phone
Comes with 3 skins - Shades, Wooden, Metal
Download new skins from the web
Free Skinz Guide to allow easy creation of new skins
Send installed skins via IR, Bluetooth and Email
Free 7 day trial
[/list:u]
Hehe, there truly is more than one way to skin a smartphone!
If you do not Restart the phone.... you'll get a lot of system errors earlier or later. I deinstalled it but there where still system errors.
So be carefull.
If you got those errors:
* Open WildskinZ
* Switch it "Off"
* Close it
* Restart
C'Ya
Moved the trigenix part to 7650 section.
http://www.allaboutsymbian.com/phpBB2/viewforum.php?f=8
[quote="MastiX"]If you do not Restart the phone.... you'll get a lot of system errors earlier or later. I deinstalled it but there where still system errors.
Be very careful about wildskins, i recently installed a trial version and the letter inputs of my 3650 and 7650 disappeared, It was only remedied by reprogramming my phones . We suspect that BUGs did the trick :evil:
Ok i got ur problems bout the error.Heres the solution �.BEFORE uninstalling the wildskinz,make sure it was set on OFF mode.Turn it off first b4 removing it!!! then your ok.
