Cost of using the nokia maps?n95
8 replies · 3,010 views · Started 28 January 2008
Hi i was wondering how much it costs me to use the nokia maps on my n95 8gb,it always asks to conect to a server when i load it up so surly it must charge me that way.im with 3 network.
thanks
If you already have the maps loaded on to your N95 it will connect to 3 only for Assisted positioning which speeds up the gps positioning a bit but no data is transfered.
If you do not have the map data loaded on to the phone then connecting to 3 will download the maps and may incur data charges.
Use Nokia map loaded to load the maps on to your phone
Vindi
Actually, it does use data, even if its only a few kb each time. Ok for most, but if you dont have a dataplan it can cost you.
Also, even if you have the maps loaded nokia maps still needs a connection, especially using postcode search. You can turn it off, but then you dont get the full postcode search. I have no idea how much data a postcode search uses, but I imagine its very little.
if youy are using the gps i would opt for a 3rd party app like garmin as it seems to be much better. a bit off the subject but good info i would say
The amount of times Ive heard that...NO. And nor are any of the other main ones.
Currently the only free satnav software I know of is amaze, but you need a dataplan for that as it downloads maps on the go.
i can do postcode searches fine. I preloaded the maps for eurpoe and dont use o2.
So costs nothing
three charge me for browsing maps
three charge me for navigations
nothing is free on three
i have downloaded the maps using nokia map downloader
i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it i hate it
