SHARE ONLINE APP ON NOKIA ,COMPATABLE SITES:: I'm finding it hard to find any so i guess there 1000s in same situation so lets start a list to make it easy fo every one to find compatible sites
if you have setting add them too,but site name is o.k on its own
thanx guys this will be helpful for lots of ppl:icon14:
Isn't the op referring to sites which support the 'share online' feature within gallery in S60?
ie. Sharing images from phone to web?
Rather than just any old file sharing?
rutter wrote:Isn't the op referring to sites which support the 'share online' feature within gallery in S60?
That was my understanding, and I thought only Vox and Flickr were officially supported. Wish it would support Picasa too, as although I use Flickr, I'm starting to move over to Picasa, as I prefer its interface and integration with pics on my PC.
i was on about the share online feature on nokia vox and flckr are official 1's preinstalled but in settings u can add your own provider but site your adding as to use atom protocol itseasy to add just not easy finding providers if you use different from flckr or vox try adding it in your settings to see if its compatible
I really wish some people could learn to use punctuations......
