Viewing RAM on N95...?
5 replies · 4,412 views · Started 29 January 2008
Hi guy�s,
How can I view RAM usage on my N95 8G, is there a app in the phone or is it a case of installing a program to see the current usage? If a program is to be installed what is the best option and where can I find it?
Thanking you in advance.
You can get a program called Handy Taskman, it's not free though.
Try google, or the search feature on the forum.
Thanks for your quick response.
What would be best program to get if I was willing to purchase one?
Thanks.
I prefer NsysInfo to replacement task managers as these stay resident in memory, so you end up with less available RAM by using one.
Symbian Freak thinks JbakTaskMan is the best of these if you are going to use one, and its free.
s.
Thanks for that guy's, I might try them both and see what I think, I can always uninstall the one I dont like.
Thanks again...
