Has anyone been able to make the save function work on SCUMMVM games, specifically Monkey Island 2? I loved playing the game the first time, but starting from scratch (inc. the 5 mins intro) every time makes the game more or less redundant.
Saving ScummVM games
I have it running on my Nokia N95 8Gb.
Run any game as normal and save your game just after you start,
exit the program completely, then using either File Manager or Y-browser, search for save games.
This will tell you where your scumm save games are being saved to.
Re-start Scumm.
In the main screen where you find the games that you have put on your memory card, go to options.
There you will find a PATH tap, this tells the program where you are storing the save games.
Make sure you direct this path to where your save games are going to and away you go.
All the best
Beef
Excellent, your instructions were perfect. Thank you. :icon14:
