how to access mass memory ?
5 replies · 2,494 views · Started 29 January 2008
i bought n95 8gb few days back and i am unable to transfer between the mobile and PC through USB data cable .... right now data cable is the only option with me.... can anyone help!??!?! thanks in advance.
When you plug the cable in, it should give an option, choose 'data transfer'.
It should now show up in 'my computer' as another drive.
mobile is unable to connect becoz mass storage is in use by another application ????
this kinda error i get !?!?
That means you have an application running. HOld down the menu key and end anything running there.
waxup wrote:That means you have an application running. HOld down the menu key and end anything running there.
Well, anything apart from Standby.
If you want more details - hold down the menu key until a list of icons appear in the top left corner, go through them and select anything that's not Standby, press the 'c' key, press the left soft key to select Yes when prompted whether you want to close that application. Repeat until you only have Standby left, then try the cable connection again.
Most Of The Time People Have Activated The Mass Memory 4 There Text Messages....
Set This Back 2 Phone Memory ... And Try...
Also, Mayb U Have Changed The Fonts?
Then U Have 2 Have Use Fontrouter 2 Deactivate The, Becaude It's Installed In The Mass Memory
