what should I use to wipe the screen and the camera lens on the back with? any suggestions?
cleaning the phone
a coat, a t-shirt, trousers, curtain in the living room, finger, earbud, socks, boxer shorts...
Well, that's what I use and don't see any problems... 😉
A little bit of course wet and dry sandpaper.
yeah, I use rotties method too and havent any probs... yesterday I used a business card to get the pocket fluff out the cursor pad... man, I have a lot of fluff in my pocket! BWAHAHAHAH
try (pc line)universal cleaner from pc world.
kontraband wrote:yeah, I use rotties method too and havent any probs... yesterday I used a business card to get the pocket fluff out the cursor pad... man, I have a lot of fluff in my pocket! BWAHAHAHAH
Old toothbrush is the best for pocket fluff! Tested!😉
bit of daz set to setting 3 and a spin dry to finish! baby wipes work for me but i have gave up cleaning it now!
should shift it just dip in the above and it will come out clean as a new penny😃
use acetone(nail remover) to clean the screen. it removes all dirt
lp4u wrote:use acetone(nail remover) to clean the screen. it removes all dirt
how much dirt do you get on your phone!!! :con?
kontraband wrote:how much dirt do you get on your phone!!! :con?
It must be from using Massager application...😉
