Can't uninstall Share Online 3.0 from Nokia N95
4 replies · 7,436 views · Started 31 January 2008
I installed Share Online 3.0 on Nokia N95 and it installed successfully. Now when I uninstall it in normal way, N95 displayes it to be uninstalled successfully, but it is still present in the applications folder and working. I want to release the space occupied by it on the memory card.
Can anybody advise as to what to be done to uninstall it completely
Hi.. I have read on a blog somewhere(can't remember which one, sorry) that someone else is having the same problem so your not alone. The bad news is that they haven't found a way to remove it either.. Sorry I can't be any help
I have Share online on my PC ready for installation.
However I was able to successfully uninstall it and reboot from my phone.
Rebooted twice and it automatically came back - without connecting to PC Suite.
I can launch it but I cannot remove it. I've uninstalled Nokia WebServices thinking it was the application - since Share Online is not listed in App Manager. Still nothing.
what firmware version do you have? if it's v21, then share online v2.1 is the one remaining after uninstalling v3.0 (because it's in the firmware)
