hello all,
can you help with advice how to increase the volume in earpice of nokia 6600. The volume control is at full but still the volume is low.
I believe this is not my phone problem but all 6600.
advice plz.
thx
6600 earpiece sound low
MOGUUR wrote:hello all,
advice plz.
thx
This is an easy fix, the same as a phone I bought recently. The volume is low as the tiny holes in the case have become blocked. Ease the from cover off and then insert a tiny screwdriver from the inside. Note the centre hole has gauze over it and becomes particulary blocked.
This will make a huge difference to the volume of your ear piece.
thx kawakiman, worked great problem solved:icon14:
