Firmware Upgrade
7 replies · 2,953 views · Started 01 February 2008
I have the 7.24 version on my E90. How can I update the software as when I input my product code it tells me that the software I am running is already latest. Is the 7.40 version better?
I have read on the forum that it can be done by changing the product code. Could anyone advise how I can do that?
You do it from PC Suite. Make sure you are running PC Suite 6.85.14.1 and select Upgrade phone software from the File Menu.
Thank you very much. Just one silly question. What product code do I use so that I do get the 7.40 update. I am in the UK on O2.
Thank you very much. One final question. Is there a real advantage in moving from 7.24 to 7.40.
Also once I change to 7.40 the warranty becomes invalid. So if I do have a problem and I need to send the phone to Nokia will be able to reflash to 7.24 by changing the product code to my original code which is 0553342.
Also I have quite a lot of softwares which I have purchased..eg Nokia Map navigation, Quick office, Handy Tools. When I reinstall them will my unlock codes work or will I need to contact the vendours for new unlock codes
