hi
is AD2P works on e90 yet?
any n95 8gb adopter here? any suggestions?
thanks
ad2p on e90?
Hi
Nokia BH-500 (stereo bluetooth headset) works ok on my E90
does it has to be a nokia one, or any bluetooth headset can work?
like sony ds-970?
Jes others're working too. I am using jabra and wery satisfied with it.
Cheers,
it works but i have to simply connect it from phone, it doesn't just play songs or connets as a audio device unless connect it from phone, which is so incomvinienent (spel). and if the audio device cancels, music plays in background through speakers and its bad!!, i was in room with bunch of people presenting, and this as soon as my bluetooth headset battery was gone, the phone was playing music in background.. soo ambarast
I'm using jabra bt320s.
My experience:
- autamaticly connects to my e90 after switch on.
- spceail profile set up and change automaticaly for the headset
- crystal clear sound quality with dynamic bass
- auto volume leveling when call comes in or goes out.
- one button answer and dial
- controls music player.
- possible to replace headset with a jack plug and connect it to any hi-fi system (cool!!!)
- also possible to plug your own high-end headphones in
- autamicly disconnects when switched off.
- rechargable
- only $40
Cheers,
This headset works brilliantly with the E90 here. Strangely(?), works even better with my iMac, as an aside, as that's what I mostly use them for!
Tim
