Hangup call with slider: Freeware
21 replies · 7,762 views · Started 02 February 2008
Whoo Hooo!
Thanks Matey, will give it a go :icon14:
OK.. tested it and it works perfectly even after a reboot (Been waiting sooooo long for this!)
Nothing application wise appears anywhere, just wondering if anyone tries it and decides not to use it, is there a way to turn it off without removing it?
Thanks very very much for this
Jay
codiac wrote:Whoo Hooo!
Jay
It's sticky in the background and has no icon..
So u will have 2 delete it from the app manager
As i am new to this stuff I do not know anything about signing software. I would like to try this application so can anyone please explain to me how I go about doing so.
Cheers
works great, thanks. just had to turn lock keypad on after defined period as ending the call using slider doesn't lock the keypad anymore but no big deal to do this.
I know this has got to be one of the most asked questions, and i hate repeating stuff as i know most people do.
But could someone explain teh signing process in simple terms? I tired to sign RotateMe but couldnt work that out, so will be the same for this.
Im usually good with computers too.
Any help would be great. Cheers 😊
zippiracer wrote:why I am getting certificate error
You need to sign it... Look at the pervious page...
Firstly id like to thank rolan for supplying this software! Have waited for this since ive had my N95...
rolan, are you the creater of this software? If not who do we contact for well I
dont know if its a bug, but info on the software? Theres a couple of things I have noticed with the program.
Actually ill list them here:
1) If you make a phone call from the the Dialled Numbers of Contacts and hang up before the person answers for what eva reason the Contacts or Dialled Numbers list stays open and does not lock the keypad. Is there anyway of closing these when the slider is closed?
2) Also as stated on the first page the keypad doesnt lock straight away like it would if you was not in a phone call. You have to wait for the auto keylock to work...
Many thanks!!!
Well i installed it...1st phone call i got i slid the phone open to answer and it didnt answer the call. Must be something to do with the app as its never happened before. Ive uninstalled it for now as id much rather the phone answered by sliding than hung up by closing.
Matt.C wrote:Well i installed it...1st phone call i got i slid the phone open to answer and it didnt answer the call. Must be something to do with the app as its never happened before. Ive uninstalled it for now as id much rather the phone answered by sliding than hung up by closing.
I was going to mention that too... Ive had that problem also...
Mitchem wrote:I was going to mention that too... Ive had that problem also...
Yeh, must be a big, would seem stupid to remove the slide open to answer functionality.
software now removed as it affected voice conversation quality. after removing it, everything went back to normal
staying away
For me it didn't work at all. Slider closing does not end the call, at least not for outgoing calls. I haven't had opportunity to test on an incoming. I'm not popular enough 😊
