TV Out doesn't work with Onkyo
2 replies · 2,040 views · Started 02 February 2008
I've got this little problem with N95 8GB. I am a proud owner of the ONKYO 503 Amplituner. On front panel, I got three standard slots, Video, L Audio, R Audio. I put a Nokia cable in it and... sound works perfectly good, but there is no video on TV. I tried all the A/V channels with no success. BUT If I put Nokia cable directly on the back slots of the TV, I got a VIDEO, but no sound! Any suggestions?
hi there,have you tried to checked your TV out settings? under TV system,try switching from NTSC to PAL,vice versa..
Just figured it out. I had to use Composite cable to connect Amplituner with TV. I already got Component cable, but Component seems to not work with my phone.
Attachments: kabel.JPG
