Music
7 replies · 2,665 views · Started 03 February 2008
Hi everybody,
I'm new here so please be patient 😊
Is there a way I can transfer music to my N95 so that it will play random tracks?
When I use the USB Windows media conection, it will select random songs but once on the N95 they are all in album folders and I cannot see a way to randomise them.
Another question:
Can one limit the amount of songs that will be transfered? (as in GB on the card). What I mean is, if I only want 400mb of songs for example, can I set that?
Thanks guys.
i dont understand do you mean transfer random tracks to phone or play random tracks on the phone once they have been transfered?
yes just open music player play any song then click options scroll to shuffle and sellect on
as for limiting the size just check the size of the songs you are adding as it is up to you which songs you transfer. what are you using to transfer them?
No, what I meant was - in Windows Media you can select to randomly select songs to transfer to the phone, but if you do this it will fill your card. What I want to do is always leave, say, 200mb free for photos for example.
i see. i didnt even know you could do that. well im not sure but if you have alot of songs im guessing it will just copy them untill the card is full. not too sure though as i have never used it. you can get larger cards for a reasonable price now if you took that option
